Skid Plates
    Skid Plates
    Added some skid plates to my bronco today. Wish I would have added them the day I picked it up.
    I had to straighten the shock mounting plates to fit
    the skid plates over them. The front crossmembers are bent up some also.
    Click image for larger version  Name:	IMG_7313.jpg Views:	0 Size:	164.1 KB ID:	2737
    Click image for larger version  Name:	IMG_7314.jpg Views:	0 Size:	127.6 KB ID:	2739 Click image for larger version  Name:	IMG_7317.jpg Views:	0 Size:	159.4 KB ID:	2740 Click image for larger version  Name:	IMG_7316.jpg Views:	0 Size:	159.2 KB ID:	2741 Click image for larger version  Name:	IMG_7318.jpg Views:	0 Size:	141.2 KB ID:	2742
    I just got done ordering 3 items for the Bronco, just received one of them.
    I just got the front differential skid plate from Extreme Terrain, brand is ICON Impact, and it looks better than I expected and is very heavy duty.
    I also have Pinch weld skids and front control arm skids coming today.
    So far I have put on the Rear Shock skids from DV8 and also the Rear Control arm skids from also DV8.
    Can’t wait to get these bad boys installed!!! ​ ​
ID:	4739 Last night I took off the running boards and added the Pinch Weld Skids from DV8, and they do look amazing.
      Click image for larger version  Name:	IMG_7304.jpg Views:	3 Size:	220.1 KB ID:	4709 Click image for larger version  Name:	IMG_7305.jpg Views:	3 Size:	240.6 KB ID:	4710
        I just spent a couple of hours installing the rest of my body armor, and I would have to say that I’m pretty impressed with how easy it went on and how it looks.​
ID:	4734 Click image for larger version
ID:	4735 Click image for larger version
ID:	4738 Click image for larger version
ID:	4736 Click image for larger version
ID:	4737 Click image for larger version
          I added the tranny skid plate yesterday. Click image for larger version
            Maybe that is what I need to cover the cross over of the exhaust system that looks like it could easily get hit by a rock looking at the picture. Click image for larger version
              Dang, I can't believe how new everything looks under there!
                I guess that’s the advantages of living so close to work, 2 years old and that’s all I have in miles.
                Most of the miles are going up North several times a year and once out to Moab.
                If they wouldn’t spread salt all over the place even if it’s just rain, it would look like I just took it off the lot.
                Just don’t look under the hood, it’s the only place I haven’t cleaned yet…..
                  Figured I would catch up to some old information and add to it as far as skid plates.
                  This past summer 2025 I have added the underside transmission skid plates from Mabett, I thought for sure it would have went together well with my Icon differential skid, but I was wrong.
                  I had to modify the Icon skid just a little with a grinder to make it fit, an hour later it fits perfectly……
ID:	5245 Click image for larger version
